8.9 Missing Data Imputation
Time-series data in industrial environments frequently has gaps — sensors go offline, network interruptions delay data delivery, or hardware faults cause temporary measurement loss. Missing data imputation fills these gaps with estimated values, ensuring that downstream analyses, averages, and KPI calculations are not skewed by missing readings.
note
Missing data imputation via TDgpt requires the TDgpt module to be installed alongside IDMP. It does not require an LLM connection.
IDMP provides AI-based imputation through TDgpt, which uses learned patterns from the signal's historical behavior to estimate what the values during a gap should have been.
How Imputation Works
TDgpt's imputation capability operates on a time window of historical data around a gap. It applies a trained model to predict the most likely values for the missing timestamps and writes those estimates back into the data. The imputed values are flagged as estimated, distinguishing them from actual sensor measurements.
Imputation is complementary to TDengine's native interpolation functions (INTERP, FILL). Native interpolation uses simple strategies (linear, previous value, next value) and is suitable for short, predictable gaps. TDgpt imputation uses learned patterns and is better suited for longer gaps, irregular signals, or cases where simple interpolation would produce unrealistic values.
Configuring Imputation
Imputation is configured directly from a Trend Chart panel. Open a Trend Chart that displays the attribute with missing data, then use the imputation control icon on the right side of the chart to enable imputation and select the method.
Supported TDgpt Algorithms
AlgorithmCharacteristics
MEANFills gaps with the local mean of surrounding values — fast and robust for stable signals
IEMIterative expectation-maximization — suitable for correlated multivariate signals
LSTMPyTorch LSTM model — captures temporal dependencies for complex, non-stationary signals
TDtsfmTDengine's time-series foundation model
Viewing and Toggling Imputation in a Trend Chart
Imputed values appear in Trend Chart panels and attribute history views alongside measured data, visually distinguishable from actual sensor measurements.
In the Trend Chart panel, an imputation control icon on the right side of the chart lets you toggle imputation on or off directly from the chart view, without changing the attribute configuration. Use this to compare the raw data (with gaps) against the imputed view.
