Data Visualization
TDengine IDMP provides panels and dashboards for visualizing data. Every element in the system can have its own panels and dashboards.
Elements at different levels typically focus on different metrics depending on their position in the tree hierarchy. For example, a dashboard for the entire power company might focus on total power generation and overall cost, while a dashboard for a wind turbine might display the operational status and generation efficiency of a specific turbine.
Basic Panel Operations
TDengine IDMP panels support the following types of visualization:
- Trend charts
- Bar charts
- Pie charts
- Gauge charts
- Tables
- Rich text
- Stat values
When viewing a panel, you can click the icons in the action bar to edit the panel, set it as a favorite, specify the time range, zoom out, adjust refresh frequency, download the panel as an image, zoom in on a specific display area, or enter full-screen mode. Below the panel is a legend, where clicking a label will toggle the visibility of that metric.
Click the Edit (pencil) button to enter editing mode. The following section provides a more detailed explanation of panel editing operations.
Types of Data Displayed in Panels
When creating a panel for an element, you can choose the following from the sidebar:
- Element: You can select attributes of the current element or of its child elements to use as display metrics. The system only lists attributes whose data reference type is TDengine Metric, as only these represent time-series data that is meaningful to visualize.
- Child Element Grouping: You can select a child element template from the children of the current element, then choose which attribute of that template to aggregate. You can also select one or more dimension metrics for grouping.
The default selection is Element. In the left tree structure, select a specific metric or tag and double-click to add it. Alternatively, you can click the three dots to its right and select "Add to Metrics" or "Add to Dimensions".
Panel Metric Configuration
For each metric, you can configure the following options:
- Name: Name displayed on the panel for the metric. By default, the attribute name is used.
- Expression: Supports expression calculations on the selected attribute, or allows selecting multiple attributes for calculation.
- UOM: Sets the display unit for the metric. It can be adjusted to other units within the same measurement category.
- Conditions: Filter conditions applied to the raw data to refine which data points are visualized.
- Time Shift: Offset for the timestamps of the metric. This is used to compare trends across different time periods. For example, setting it to
-1dmeans the panel will show data from the same time one day earlier. - Prediction : Time-series forecasting for the selected metric.
- Order By : Sorting for the metric. By default, no sorting is applied.
For all displayed metrics, you can also configure the following options in the top-right corner of the metric list:
- Limit : Maximum number of data points displayed for the metric.
- Window : Sliding window aggregation to the metric. You can set the interval and the window duration.
Panel Dimension Configuration
In the sidebar, double-click on a dimension to select it. For each selected dimension, you can configure the following options:
- Name: Name displayed on the panel for the dimension. By default, it uses the attribute name.
- Expression: This indicates that dimensions can be used for calculations before being displayed as dimensions in the panel.
- Conditions: Filter conditions applied to the dimension.
- Group By: Aggregates data by dimension. Enabled by default.
- Order By: Sorting for the dimension. By default, no sorting is applied.
tbname as a special dimension, if the expression is empty, will only be used for grouping and sorting, and will not be returned to the panel dimensions.
Operations on Panel Metrics or Dimensions
In the metric or dimension list, each item supports the following operations:
- Delete: Removes the current metric or dimension. This action cannot be undone, so please proceed with caution.
- Up: Moves the metric or dimension up, changing its display order in the chart.
- Down: Moves the metric or dimension down, changing its display order in the chart.
Adjusting the display order of metrics or dimensions can optimize the data presentation on the panel, highlighting the most important data.
Advanced Panel Configuration
After enabling "Advanced", you can add multiple advanced SQL queries here and display the query results simultaneously in the same panel.
In each advanced SQL query, you can choose one of the following two types of queries:
- TDengine: Query using the TDengine connection associated with the current element or element template.
- Event: Query events generated internally by the system.
After entering a complete SQL query, you can click the "Verify" button to verify whether the current SQL is valid and executable. After successful validation, a green icon will appear next to the button indicating success. At this point, you can click on the two selection boxes below to make selections:
- Time Column: If you want to use a specific column from the query results as the time column, you can select or deselect it.
- Dimensions: If you want to set some columns of the result as dimensions, you can select one or more columns as dimension columns.
Advanced queries also support the following three replacement parameters:
${FROM_TIME}: Used in a panel or dashboard to substitute the start time from the time picker.${TO_TIME}: Used in a panel or dashboard to substitute the end time from the time picker.${Element#fullVirtualTable}: Used in element templates to substitute the full virtual table of the element passed into the panel or dashboard element selector.
- All of the above parameters support autocomplete: in the SQL editor, typing
FROM_TIMEwill autocomplete to${FROM_TIME}, typingTO_TIMEwill autocomplete to${TO_TIME}, and typingELEMENTwill autocomplete to${Element#fullVirtualTable}. - When
${FROM_TIME}and${TO_TIME}are substituted, they will automatically determine whether to add single quotes based on context; you do not need to add quotes when using these parameters. - When
${Element#fullVirtualTable}is substituted, it will automatically determine whether to add backticks based on context; you do not need to add backticks when using this parameter.
Additionally, you can click the "Format" icon to format the current SQL query, and you can also enable or temporarily disable the current SQL.
Panel Display Settings
While a panel is in edit mode, you can modify the display settings for the panel on the right sidebar. Any changes you make are immediately reflected in the main area for you to preview.
Panel Card or List View
Panel lists are displayed in card view by default and can be switched to list view. Each panel can be viewed, edited, deleted, or converted to a template through the menu. If a panel does not contain child element attributes, it can be converted to a template.
Sharing Panels
Panels support sharing functionality. On the panel view page, click the share icon in the top-right corner, set the sharing duration, and generate a unique sharing link. Through this link, other users can access and view the panel, and it can also be embedded in third-party application pages.
