12.3 Building Data Models from TDengine TSDB
For users who already have data in TDengine TSDB, IDMP can automatically build the asset data model — elements, element templates, and attributes — directly from the TSDB schema. This eliminates the need to create elements and attributes manually.
IDMP provides four approaches, all accessible from the TDengine connection detail page under Admin Console → Connections → [connection name]:
| Tab | Best for |
| Easy Import | Well-structured TSDB data with hierarchical location tags — fastest path to a complete model |
| Map STable to Element | Data without location tags, or when mapping multiple supertables to one element template |
| Import from CSV | Bulk configuration via a CSV file, especially for single-column data models with many supertables |
| Import from OPC | OPC-structured data already in TSDB |
12.3.1 Easy Import
Easy Import works best when your TSDB supertables already have a tag that encodes the asset hierarchy — for example, a location tag whose value is a dot-separated path like Plant.Line1.Machine3. IDMP maps each supertable to an element template and each child table to an element instance.
How to use:
- Select the Database and Supertable at the top of the page. Check Ignore to skip a supertable entirely.
- In the Tags section, configure each tag:
- Check Path to use the tag value as the element's location in the asset tree. Set Path Level (0 = leaf) to control hierarchy depth. Optionally set a Parent Element to root the import under an existing element.
- Leave Path unchecked to import the tag as a static attribute (element property).
- Use the Rename field to give the attribute a display name different from the TSDB column name.
- Optionally assign an Attribute Category.
- In the Metrics section, check Map STable to Element for each metric column you want to import as a dynamic attribute. Use Rename and Attribute Category as needed.
- Optionally set an Element Category and a Subtable Filter (a SQL WHERE-style expression to include only matching child tables).
- Click Next Supertable to proceed to the next supertable, or click Finish to complete the configuration immediately using defaults for remaining supertables.
A summary at the bottom of the page shows how many tags and metrics are selected for the current supertable, and the total count of supertables selected versus ignored.
Auto-sync: After the import task runs, IDMP monitors the TSDB for metadata changes. New child tables added to a configured supertable are automatically synced as new elements — no manual intervention required.
Rebuild: If new supertables are added to the database, click Rebuild to re-open the configuration with existing settings pre-loaded. Add the new supertables and save.
Data enrichment: After import, enrich each element with units of measure, descriptions, categories, and limit thresholds to give the data business context and make it AI-ready.
12.3.2 Map STable to Element
Use this approach when your TSDB data lacks a hierarchical tag, uses a single-column model (one supertable per measurement), or when you need to map columns from multiple supertables to a single element template.
IDMP internally creates virtual supertables and virtual tables to merge data from multiple supertables into a unified element — this process is transparent to the user.
The Map STable to Element tab shows a list of configured asset models with columns: Database, Supertable, Element Template Name, Status, Create Time, and Update Time.
Click + Add New Asset Model to configure a new mapping. The form includes:
| Field | Description |
| Database | The source TDengine database |
| Supertable | The source supertable |
| Element Template (required) | The element template to map to. Must be created in Libraries before starting. |
| Element Name (required) | Expression defining the element name. Click + to insert substitution strings (e.g., tag values). Click the preview icon to verify the result. |
| Element Path (required) | Expression defining the element's location in the asset tree. Use dots to separate hierarchy levels, e.g., ${location}.${rack}. Click the preview icon to verify. |
| Element Category | Optional category tag for the created elements |
| Tags | Map each supertable tag to an attribute template on the element template, or select None to discard it |
| Metrics | Map each supertable metric column to an attribute template, or select None to discard it |
| Subtable Filter | Optional filter expression to include only matching child tables |
Click Finish to create the asset model. Each asset model covers one supertable-to-template mapping. For a complete single-column data model, create one asset model per supertable (or per subset of metrics).
Auto-sync: New child tables added to mapped supertables are automatically synced as new elements.
If new supertables are added to the database after setup, you must manually add a new asset model for each. New supertables are not picked up automatically.
12.3.3 Import from CSV
CSV import is a bulk alternative to Map STable to Element. It is most useful when you have many supertables to configure — especially single-column models — and prefer to define all mappings in a spreadsheet rather than through the UI.
Workflow:
- Click the export icon (download) in the toolbar to export a CSV configuration template based on your TSDB schema. Select the databases and supertables to include. Optionally check Export child table names to include individual child table names for cases where each child table needs a specific element name or path.
- Edit the CSV file to fill in element name expressions, element path expressions, attribute template mappings, and other settings.
- Click the import icon (upload) in the toolbar to upload the completed CSV file. The import task starts immediately.
The task history table shows: Created At, Status, File Name, and Reason (if failed).
Auto-sync: Tasks without a specific child table name filter automatically sync new child tables added to the database.
CSV file format rules:
- Comment lines start with
#and are required — do not delete them. - The first non-comment row is the header row.
- Data is divided into blocks; each block starts with a row that sets the Database Name and Supertable Name.
- If no element template is specified, one is created automatically using the supertable name.
- The Element Name Expression supports substitution strings like
${tbname}(child table name) or tag values like${tag_name}. - The Element Path Expression supports the same substitutions. A dot in the value automatically creates hierarchy levels.
- Reference Type must be
TDengineMetricorTDengineTag. - The file must be encoded in UTF-8 (not UTF-8 with BOM). If editing in Excel on Windows, convert the encoding before uploading.
If new supertables are added to the database after a CSV import, create a new import task for those supertables. Existing tasks do not pick up new supertables automatically.
12.3.4 Import from OPC
Use this approach when OPC-structured data is already stored in TDengine TSDB and you want to build the asset model from it.
The Import from OPC tab shows the following configuration per database:
| Parent Element | An optional existing element to root the imported elements under |
| Ignore | Check to skip this database |
For each supertable in the database, configure:
| Column | Description |
| Checkbox | Include or exclude this supertable |
| Super Table Name | The supertable to import |
| Path | The tag column whose value represents the OPC node path |
| Data Column | The metric column containing the data values |
| Quality Column | Optional tag or column containing the data quality value |
| Path Level | The depth offset within the path hierarchy |
Navigate between databases using Previous Database and Next Database, then click Finish to create the import task.
