10.3 Using the Add-In
Once connected to IDMP, the TDengine EAI ribbon tab provides all the tools for retrieving data, exploring events, filtering assets, and configuring the add-in. Each button opens a task pane on the right side of Excel where you configure the query and select an output cell.
Ribbon Overview
| Button | Description |
| Current Value | Retrieve the latest value of one or more attributes |
| Archive Value | Retrieve the attribute value at a specific point in time |
| Raw Data | Retrieve raw time-series data over a time range |
| Sampled Data | Retrieve time-series data sampled at a regular interval |
| Timed Data | Retrieve the attribute value at specific timestamps |
| Calculated Data | Retrieve aggregated (calculated) values over time windows |
| Time Filtered | Retrieve data filtered by a state or condition expression |
| Event Explore | Query and export events from IDMP |
| Attribute Filter | Search and export attribute metadata |
| Asset Filter | Search and export element (asset) metadata |
| Properties | Retrieve a specific metadata property of an element attribute |
| Update | Refresh all data in the workbook |
| Settings | Configure global add-in settings |
Common Fields
Most data retrieval forms share the following fields:
| Field | Description |
| Data Items | The IDMP element attributes to query. Click the search icon to browse the asset hierarchy and select one or more attributes. |
| Output Cell | The Excel cell where results will be written. Defaults to the currently selected cell (e.g., Sheet1!A1). |
| Time Position | How timestamps are written alongside the data: No Time Stamp (values only), Time at Left (timestamp in the column to the left), or Time on Top (timestamp in the row above). |
Click OK to insert data and close the pane, or Apply to insert data and keep the pane open for further queries.
Current Value
Retrieves the latest value of the selected attributes and writes it to the output cell.
| Data Items | The attributes to query (required) |
| Output Cell | Target cell |
| Time Position | No Time Stamp / Time at Left / Time on Top |
Archive Value
Retrieves the attribute value at a specific historical timestamp, with gap-filling support.
| Fill Type | How to fill if no exact value exists at the timestamp: Previous (use the last known value before), or other fill strategies |
| Time Stamp | The specific timestamp to query (required) |
Raw Data
Retrieves all raw time-series data points within a time range, with no aggregation.
| Start Time | Start of the time range (required) |
| End Time | End of the time range (required) |
| Output Cell | Top-left cell of the output range |
Sampled Data
Retrieves time-series data resampled at a regular interval over a time range. Use this to get a uniformly-spaced series regardless of the original data frequency.
| Time Interval | The resampling interval (e.g., 1h, 30m, 1d) |
| Filter Expression | Optional filter to exclude certain data points before sampling |
Timed Data
Retrieves the attribute value at one or more specific timestamps that you provide, with fill support for gaps.
| Fill Type | How to fill if no exact value exists at a given timestamp (e.g., Previous) |
| Time Stamp | The specific timestamp(s) to query |
Calculated Data
Retrieves aggregated data over regular time windows — for example, the hourly average, daily maximum, or sum per shift.
| Time Interval | The aggregation window size (e.g., 1h) |
| Filter Expression | Optional filter applied before aggregation |
| Aggregation Function | The aggregation to apply (required). Supports all TDengine selection and aggregation functions that return one row of data per window (e.g., AVG, MAX, MIN, SUM, COUNT, FIRST, LAST, TOP, BOTTOM). |
| Time Options | Optionally show Start Time, End Time, or Max/Min Time columns alongside the aggregated values |
Time Filtered
Retrieves data filtered by a state or condition defined by start and end expressions — useful for extracting data only during specific operating conditions (e.g., when a machine is running).
| Expression — Start With | The condition expression that marks the beginning of a valid period (required) |
| Expression — End With | The condition expression that marks the end of a valid period (required) |
| Start Time | Start of the search range (required) |
| End Time | End of the search range (required) |
| Time Interval | Interval for data points within each valid period |
| Time Units | The unit for the time interval (e.g., Second) |
| Time Options | Optionally show Start Time and/or End Time columns |
Event Explore
Queries IDMP events and exports the results as a table in the spreadsheet. Supports filtering by multiple criteria.
| Name | Filter by event name |
| Description | Filter by event description |
| Template | Filter by event template |
| Severity Level | Filter by severity (All, Warning, Critical, etc.) |
| Is Ack | Filter by acknowledgement status |
| Created at | Filter by event creation time range |
| Updated at | Filter by last update time range |
| Maximum Results | Maximum number of events to return (default: 1000) |
| Order By | Sort field, with ASC or DESC order |
| Element Criteria — Root Path | Limit results to events associated with elements under a specific asset tree path |
| Output Cell | Top-left cell of the output table |
| Columns to Display | Select which event fields to include as columns in the output table. A multi-select picker lets you choose from all available event fields (e.g., Ack, Status, and more). |
Attribute Filter
Searches IDMP attribute metadata and exports the results as a table. Useful for auditing your data model or building dynamic references.
| Attribute Name | Filter by attribute name |
| Attribute Description | Filter by attribute description |
| Attribute Categories | Filter by attribute category tag |
| Attribute Value Type | Filter by data type (Float, Int, Bool, etc.) |
| Maximum Results | Maximum number of results (default: 1000) |
| Element Criteria | Filter by the element that owns the attribute: Root Path, Name, Description, Categories, Template |
| Columns to Display | Select which attribute fields to include as columns in the output table. A multi-select picker lets you choose from all available attribute fields (e.g., Name, Description, and more). |
Asset Filter
Searches IDMP elements (assets) and exports the results as a table.
| Root Path | Limit results to elements under a specific path in the asset tree |
| Name | Filter by element name |
| Description | Filter by element description |
| Attribute Name | Filter elements that have an attribute matching this name |
| Attribute Description | Filter by attribute description on the element |
| Categories | Filter by element category |
| Template | Filter by element template |
| Created at | Filter by element creation time range |
Properties
Retrieves a specific metadata property of an element attribute (such as its unit, description, or configured limits) and writes it to a cell.
| Data Items | The attribute to query (required) |
| Property | The metadata property to retrieve (e.g., unit of measure, description, Hi limit) |
Update
Click Update in the ribbon to refresh all data in the workbook. Every cell that was populated by the TDengine EAI add-in is re-queried with its original parameters and updated with the latest results.
Use this to keep a workbook current without reopening each form individually. For automatic periodic refresh, configure the Interval in Settings.
Settings
Configures global defaults for the add-in.
| Time format | The format used when writing timestamps to cells (default: YYYY-MM-DD HH:mm:ss) |
| Number format | The Excel number format applied to numeric output cells (default: General) |
| Maximum event count | Default maximum results for Event Explore queries (default: 1000) |
| Maximum filter search count | Default maximum results for Attribute Filter and Asset Filter queries (default: 1000) |
| Interval (seconds) | Auto-refresh interval in seconds. Set to 0 to disable automatic refresh. |
Click Confirm to save settings.
