15.2 MCP Interface
IDMP exposes its MCP integration through reverse-proxied remote endpoints. AI agents do not need to install a local MCP server. Instead, they connect directly to the endpoint provided by IDMP and can read element context, time-series attributes, events, analyses, panels, and dashboards, while performing controlled write actions within the user's permission boundary. Streamable HTTP is the recommended transport. SSE remains available for agents that still depend on it.
15.2.1 Typical Use Cases​
  • Connect MCP-aware agents directly to IDMP elements, attributes, events, analyses, panels, and dashboards.
  • Bring live industrial context into LLM workflows for element health checks, alarm investigation, and natural-language question answering.
  • Standardize multi-step workflows such as shift handover, alarm triage, and batch review, reducing manual context assembly.
  • Create analyses, alarm rules, panels, attributes, and annotations within a controlled write boundary instead of exposing broad administrative CRUD.
15.2.2 Getting a Login Token​
  1. Sign in to the IDMP Web UI.
  2. Click the avatar in the upper-right corner to open the personal information dialog.
  3. Copy the value shown in Login Token.
  4. The Login Token field shows the value part of the Authorization header, in the form Bearer <token>. It already includes the Bearer prefix, but it does not include the Authorization: field name. For clients that accept an Authorization header, place this value in the Authorization field.
If a client expects only the raw Bearer token instead of the full header value, remove the leading Bearer prefix before filling that field.
If the token expires or you sign in again, reopen the avatar dialog and copy the latest token.
In the sections below, <IDMP_LOGIN_TOKEN> means the login token copied from the UI, in the form Bearer <token>. It already includes the Bearer prefix but does not include the Authorization: field name. <IDMP_BEARER_TOKEN> means the raw token value after removing that prefix.
15.2.3 Streamable HTTP Access​
Streamable HTTP is the recommended remote MCP transport and should be the default choice for clients that support the newer MCP transport model.
15.2.3.1 Endpoint and Authentication​
ItemValue
Recommended base addresshttps://<IDMP_HOST>:6034
Transport typehttp
MCP URLhttps://<IDMP_HOST>:6034/api/v1/mcp/stream
AuthenticationAuthorization: <IDMP_LOGIN_TOKEN>
Default HTTPS port6034
HTTP troubleshooting URLhttp://<IDMP_HOST>:6042/api/v1/mcp/stream
Replace <IDMP_HOST> with your actual IDMP domain or IP address. Use HTTPS for production traffic. Switch to the HTTP URL only when you are troubleshooting certificate or network issues.
15.2.3.2 Claude Code​
Claude Code can add a remote MCP server from the command line:
claude mcp add --transport http tdengine-idmp \
https://<IDMP_HOST>:6034/api/v1/mcp/stream \
--header "Authorization: <IDMP_LOGIN_TOKEN>"
If you want to share the configuration with the current project, add --scope project.
15.2.3.3 Codex​
Codex can configure a remote MCP server in ~/.codex/config.toml. It is recommended to keep the token in an environment variable:
[mcp_servers.tdengine-idmp]
url = "https://<IDMP_HOST>:6034/api/v1/mcp/stream"
bearer_token_env_var = "IDMP_BEARER_TOKEN"
Before starting Codex, make sure IDMP_BEARER_TOKEN is available in the current shell and does not include the Bearer prefix.
15.2.3.4 Copilot CLI​
GitHub Copilot CLI supports adding a remote MCP server through the interactive /mcp add command. Inside an interactive copilot session, run:
/mcp add
Then fill in the form with values like these:
FieldValue
Server Nametdengine-idmp
Server TypeHTTP
HTTP Headers{"Authorization":"<IDMP_LOGIN_TOKEN>"}
You can also edit Copilot CLI's configuration file directly at ~/.copilot/mcp-config.json:
"mcpServers": {
"tdengine-idmp": {
"type": "http",
"url": "https://<IDMP_HOST>:6034/api/v1/mcp/stream",
"headers": {
"Authorization": "<IDMP_LOGIN_TOKEN>"
15.2.3.5 Generic Form and JSON Examples​
If your agent provides an interactive form, fill it with values like these:
FieldValue
Type / Transporthttp
For other agents that support JSON-style configuration, use a structure like the following:
"mcpServers": {
"tdengine-idmp": {
"type": "http",
"headers": {
15.2.4 SSE Access​
SSE is intended for clients that still depend on the SSE transport. Use it only when your agent explicitly requires SSE.
15.2.4.1 Endpoint and Authentication​
ItemValue
Transport typesse
MCP URLhttps://<IDMP_HOST>:6034/api/v1/mcp/sse
HTTP troubleshooting URLhttp://<IDMP_HOST>:6042/api/v1/mcp/sse
Replace <IDMP_HOST> with your actual IDMP domain or IP address. Use HTTPS for production traffic. When you need to troubleshoot certificate or network issues, keep the /api/v1/mcp/sse path and only switch the protocol and port temporarily to HTTP and 6042.
15.2.4.2 Generic Form and JSON Examples​
FieldValue
Type / Transportsse
"mcpServers": {
"tdengine-idmp": {
"type": "sse",
"url": "https://<IDMP_HOST>:6034/api/v1/mcp/sse",
"headers": {
15.2.5 Transport Selection Guidance​
  1. Choose Streamable HTTP for new integrations and newer MCP clients.
  2. Choose SSE only when the agent explicitly lacks Streamable HTTP support or you must preserve an existing SSE-compatible setup.
  3. For troubleshooting, keep the current transport path and switch only the protocol and port from HTTPS 6034 to HTTP 6042 temporarily.
15.2.6 Tool Capabilities​
The following section describes the Tool capabilities exposed through MCP.
Tool categoryWhat it coversTypical use
Elements and hierarchyRead element context, paths, child elements, and branch scopeElement lookup, asset-tree browsing, scoped discovery
Attribute dataQuery current values, history, and batch attribute data across elementsTrend analysis, state checks, cross-element comparison
Events and alarmsQuery events, acknowledge alarms, add annotations, and inspect notification historyAlarm triage, event review, notification tracing
AnalysesRead, create, pause, resume, and delete analyses or alarm rulesReal-time analysis, rule delivery, alarm automation
PanelsQuery, generate, create, and delete panelsVisualization for a single element or focused use case
DashboardsSearch and associate dashboardsCross-panel summaries and scenario-level views
AI and system metadataCall IDMP AI and read system configuration, categories, and recommendationsNatural-language Q&A, capability recommendation, metadata lookup
Controlled writesCreate attributes, annotations, and notification rule updates within the user's scopeSafe configuration changes without broad admin access
15.2.7 Resource Capabilities​
The following section describes the Resource capabilities exposed through MCP.
Resource capabilityWhen to use itReturned content
Element hierarchy and path resolutionBefore locating an element by name or building full asset-tree contextHierarchy data, path relationships, and basic metadata
Element templates and standard attributesBefore designing panels, analyses, or attribute queriesElement templates and standard attribute definitions
Event semanticsBefore interpreting template IDs, severities, and alarm meaningEvent template definitions and semantic metadata
Analysis algorithm metadataBefore creating an analysis and selecting a trigger or algorithm typeSupported triggers, algorithms, and related metadata
15.2.8 Prompt Capabilities​
The following section describes the Prompt capabilities exposed through MCP.
Prompt capabilityTypical useRecommended context
Shift handover report generationSummarize key events, annotations, and analysis results for one shiftElement context, event list, element annotations, analyses
Element health checkDiagnose the operating state of one elementElement context, key attributes, recent events
Root-cause analysisInvestigate one alarm or eventEvent details, element context, historical attributes, event annotations
Batch reviewReview one batch or bounded time windowElement context, event list, attribute history, analyses
Same-type element comparisonCompare operational patterns across similar elementsElement list, element context, events, and AI output
Maintenance-due reviewBuild a maintenance-due list and next-step suggestionsElement context, events, annotations, AI suggestions
Alarm triagePrioritize unacknowledged alarms across the systemAlarm counts, event details, element context, AI judgment
15.2.9 Frequently Asked Questions​
15.2.9.1 What should I do if HTTPS certificate validation fails?​
First verify DNS resolution, the certificate chain, and the client's trust store. If you are only troubleshooting connectivity, keep the current transport path and temporarily switch to HTTP instead: Streamable HTTP uses http://<IDMP_HOST>:6042/api/v1/mcp/stream, while SSE uses http://<IDMP_HOST>:6042/api/v1/mcp/sse. After troubleshooting, move back to HTTPS.
15.2.9.2 Why is Streamable HTTP the preferred choice?​
Newer MCP clients usually support Streamable HTTP first, and it offers clearer request, response, and error semantics. It is also a better long-term fit for future capability growth, so use SSE only when your current agent explicitly requires it.
15.2.9.3 Why do the examples use port 6034?​
6034 is IDMP's default HTTPS port, and the rest of the documentation uses the same secure external entry point. 6042 is still useful for plain HTTP access and troubleshooting, but 6034 is the recommended production-facing port.
15.2.9.4 Why can't I see every Tool, Resource, or Prompt capability after connecting?​
Agents do not all render Tools, Resources, and Prompts in the same way. Some hide capabilities until they are needed, while others display only the subset they actively support. A successful connection does not guarantee a full visual listing.
15.2.9.5 Why do some Resource or Prompt capabilities not take effect?​
Whether an agent reads Resources or invokes Prompts depends on the agent's own implementation strategy. Some agents actively use only the basic Tools and may ignore other capability types unless they are explicitly designed to consume them.
15.2.9.6 Why do write actions fail?​
Write capabilities follow the current IDMP user's permission boundary. If the token does not grant access to the target element, analysis, panel, or notification rule, the write request will fail. Check the user's role and scope first.
15.2.9.7 Why does the connection succeed but no element data is returned?​
Check whether the element path is correct, whether the current user has access, whether the queried time range actually covers the data, and whether the environment contains the expected attributes or events. For history-oriented requests, it is best to specify the time range explicitly instead of relying entirely on agent inference.
