7.1 Browsing and Managing Analyses
Analyses are managed from the Analyses tab on any element in the Explorer. Navigate to an element in the asset tree and click the Analyses tab to see all analyses configured on that element.
7.1.1 The Analysis List
The analysis list shows all analyses on the current element with the following columns:
| Column | Description |
| Name | The analysis name — click to open the analysis detail view |
| Trigger Type | The trigger type (Sliding Window, Periodic Time Window, etc.) |
| Stream Name | The underlying TDengine stream name for this analysis |
| Template | The analysis template this analysis was created from, if any |
| Categories | Category tags |
| Status | Current execution status: Running or Paused |
| Update Time | When the analysis was last modified |
7.1.2 Toolbar
| Control | Description |
| + | Create a new analysis manually — opens the analysis creation form |
| Paste | Paste a previously copied analysis onto this element |
| Refresh | Reload the analysis list |
| Auto-refresh interval | Dropdown to set automatic refresh: Off, 1s, 5s, 10s, 15s, 30s, 1m, 5m |
| Export Current List as CSV | Export the analysis list as a CSV file |
| Select Columns | Show or hide columns in the list |
The filter area above the list provides a Categories dropdown to filter by category tag, and an AI button to toggle the AI-assisted creation panel.
7.1.3 Row Actions
Hover over any analysis row and click the ⋮ (more) menu on the right to access these actions:
| Action | Description |
| View | Open the read-only detail view for this analysis |
| Edit | Open the analysis in edit mode to modify its configuration |
| Copy | Copy this analysis so it can be pasted onto another element |
| Convert to Template | Save this analysis as a reusable analysis template in Libraries |
| Trend Chart Analysis | Open a trend chart for the element, useful for inspecting analysis output |
| Fill History | Re-run the analysis over historical data to backfill output attributes |
| Pause | Pause the analysis — stops execution without deleting it (shows Resume when paused) |
| Delete | Delete the analysis and optionally delete the output data it produced |
7.1.4 Analysis Statuses
| Status | Meaning |
| Running | The analysis stream is active and executing on new data as it arrives |
| Paused | The analysis has been manually paused — no new computations run until resumed |
When you delete an analysis, a confirmation dialog asks whether to also delete the old output data that the analysis previously wrote.
